Ir para o conteúdo principal
O Lenovo ThinkPad Yoga 370 é um 2-em-1 fino, leve e ultraportátil com dobradiça de 360 graus, tela sensível ao toque com suporte a AES multitoque e LTE-A opcional para conectividade móvel. Número do modelo: 20JH002AUS.
Device not switching on
  • Why is my PC not turning on and also not charging when connected to a power source?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I need an urgent reply 😭😭
por Compartilhar
Adicionar um comentário
1 resposta
@lanry you are not really telling us a lot here. Would be nice to know what you have checked and if anything has happened to this Thinkpad. Anyhow, I suggest you start with the basics for all devices and check a few things.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lanry será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 18
Ao todo: 412
