Why is my adapter overheating
Any time I try to charge my pc, my adapter overheats after a few minutes
Esta é uma boa pergunta?
Hi @wisdomodame
It could be a faulty adapter, faulty adapter cable or a problem in the laptop.
Try using another known working, compatible adapter and check if it heats up or is OK when connected to the same laptop.
If it works OK then the problem is in the original adapter or adapter cable.
If it also heats up then the problem is on the motherboard in the laptop. The schematics would be needed to find out what's wrong on the motherboard. Unfortunately if the motherboard model number is LA-B171P (as printed on the board itself) I can't find a schematic online, you may have better luck.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 232
