My LCD screen suddenly gets overly bright.
like when you turn the brightness into overdrive or mess with the gamma. and it happens gradually, when you turn it on everything is fine but within a minute it's all blown out. the image returns to normal after i turn the contrast all the way down. it's an Philips 170s with a CCFL backlight. here is a video of the problem
Esta é uma boa pergunta?
16 comentários
I'm wondering if maybe the physical buttons on the bottom of the screen are stuck, or being pressed. When you go to adjust your screen's brightness does it feel like the buttons are compressing properly?.
por Jacob Mehnert
@jmehnert no, the buttons work still, i can still control everything. and it behaves normally.
por martijn puik
@martijnpuik The only other thing I can maybe think of is that it could be an issue with the drivers for your monitor. Have you tried uninstalling them and reinstalling them?
por Jacob Mehnert
@jmehnert it happens with every device i connect to it.
por martijn puik
@martijnpuik so the issue does happen when testing with other monitors?
por Jacob Mehnert
Exibir mais 11 comentários
