Ir para o conteúdo principal
O smartphone Android Samsung Galaxy Core Prime Duos é uma variante da linha Samsung Galaxy Core Prime. Número do modelo SM-G360H/DS (SM-G360H/Dual-Sim). Lançado em novembro de 2014.
How to change screen
How to change screen glass at home
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@msdhoni32365 use the Samsung disassembly SM G360H Disassemble Assemble for this. Instead of using a heating chamber, you could use a hot plate or a good hairdryer. The temp to reach will stay the same. Then use something like this Clampy - Anti-Clamp or similar to remove the LCD.
Replacement LCD's are readily available at many online stores. Just make sure you get the right one for your version of the phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Imagem de Suction cup pliers for easier phone repair and screen removal, powered by hands-free force application.
Produto
Clampy - Anti-Clamp
$24.95
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ms Dhoni será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 225
