Ir para o conteúdo principal
Um disco rígido SATA de 3,5" e 250 GB lançado pela Western Digital.
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
Esta é uma boa pergunta?
Pontuação 10
1 comentário
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Substituição do controlador do disco rígido Hitachi GST Deskstar HDS721010CLA332
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
Adicionar imagens a uma pergunta já existente
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Hitachi GST Deskstar HDS721010CLA332 Hard Drive Controlador
Guia
Moderado
20 minutes
Esta resposta foi útil?
Pontuação 2
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
Pontuação 0
Adicionar a sua resposta
Khushal Dhumane será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 29
Últimos 30 dias: 133
Ao todo: 4,083
