Ir para o conteúdo principal
OnePlus released its first smartwatch in April 2021. The OnePlus Watch comes with Wi-Fi, Bluetooth, 1 GB of RAM, 4 GB of storage, speakers, and GPS.
3 Perguntas Visualizar todos
cold battery will not charge where do you buy battery?
will not charge says cold battery
Update (09/25/23)
where do you buy battery for plus one watch
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Could be a bad temperature sensor.
Li-ion batteries shouldn't be charged below 40 F ( ~ 5 C) so there is a sensor to check for this.
If you warm it up, can you make the message go away?
por
Not work my wacth
por
A comedian. Very funny. My wacth (sic)
por
Adicionar um comentário
2 respostas
Pergunta mais útil
@frankdidente could be a bad battery. The battery has a temperature sensor, and a failed battery control board can give you that error. Start by replacing the battery.
Check this OnePlus Watch Teardown and see if this is something you would tackle.
Esta resposta foi útil?
Pontuação 1
I replaced the battery and it worked using battery from:
I just found this on AliExpress:
C$37.99 | new original for OnePlus XE202 Watch battery
https://a.aliexpress.com/_mOAz1z9
The wearable now works!
Pontuação 1
Adicionar a sua resposta
FRANK DIDENTE será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 242
