Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
412 Perguntas Visualizar todos
Cabrio - will not wash - only rinse or spin
Hi all... I've reset my washer to factory settings by turning the dial counterclockwise and then 3 turns clockwise, 1 turn clockwise, 1 turn counterclockwise, and one last turn clockwise. All the lights lights up which YouTube videos suggest t then turn the dial to Wash and press Start. That has worked in the past but no longer. I now hear but don't see water under the agitator as I manually move the agitator around. I've watched many YT videos and tried to contact Whirlpool without success. I very much appreciate your suggestions. Thank you.
Update (08/28/23)
It's about 10 years old.
Esta é uma boa pergunta?
Pontuação 0
4 comentários
@eagertolea90964 what is the exact model number for your washer?
por
So sorry I forgot to post - Model WTW500XWO Thank you.
por
@eagertolearn99
please confirm the model number of the washer?
I cannot find any information regarding the model number you posted.
The closest model number I found is WTW5000DW0
por
I triple checked with a brigs flashlight and excellent magnifying glass and it appears to be WTW5500XWO with one dial knob in the middle and 6 slots below that each light up, Thank you.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @eagertolearn99
Here's the tech sheet for the washer.
Run the diagnostic tests as shown on p.4 (see Automatic test mode) and check for any error codes being displayed.
There is an Fault/Error Code Display Method chart on p.3 that shows how to interpret the status LEDs if any errors are shown.
The error code meaning and possible causes are shown on p.6-p.7.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you so much! I will look at that once weather clears. Much appreciated!
por
Adicionar a sua resposta
eager to learn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 36
