Ir para o conteúdo principal
display and touch screen damage
I had kept the mobile on a tripod for videoshoot, but accidentally the mobile fell from the tripod and the display turned completely black, the touch screen is working but the display has turned black.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@rohitlohiya touchscreen and LCD are a fused unit. Going by your description,you have to replace the display assembly. Since iFixit does not yet have a guide, you want to use this one to replace your display assembly. The assembly is readily available at plenty of online stores, but you need to ensure you get one for your specific model 710F, J710FN (EMEA); J710M (LATAM); J710H (South Africa, Pakistan, Vietnam)
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Esta resposta foi útil?
Pontuação 1
My phone touch is not working
Pontuação 0
1 comentário:
Ali, has anything happened to the phone recently, such as a system update, any kind of damage or fall, or possibly exposure to liquid? When did the problem start and what have you done to try and figure out the problem?
por
Adicionar a sua resposta
Rohit Lohiya será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 352
