Ir para o conteúdo principal
Um smartphone Android básico da Micromax.
Phone is not one
Phone is hanging display is not working and phone is dead
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@paripinkushashi your "Phone is hanging display is not working" would be pretty normal when "phone is dead" The First thing I would try to find out is what it is dead. Change the battery, check the charger, check that charging port. Plug the charger in and measure the voltages on your battery connector. That voltage will have to increase. If it doesn't you are having board issue.
At bare minimum you want to get yourself a USB ammeter and plug your phone into it. Then see how many amps it draws. You gotta start somewhere, so might as well be on the power circuit.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Pari pinku shashi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 271
