Ir para o conteúdo principal
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
Why won’t my tablet reset?
My tablet won’t factory reset or a hard reset-It turns back on and gives options like reboot system factory reset, reboot to boot loader etc but it doesn’t matter what I choose (using a pin in the hole, holding down the volume button & power It just keeps coming back to the same screen-Please help
Update (08/11/23)
Hi, It’s a Visual Land Prestige Elite 801
Model number ME8CI.
It’s an older tablet
I’ve tried to post a picture of the screen it keeps defaulting to-But I must be doing something wrong.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi @amchjfj2xxe5cro,
What is the make and model number of the tablet?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
press volume down till it goes down to factory reset and press the power button
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks for responding but that doesn’t work-When I turn it on it’s that screen that appears and I’ve tried all the steps on that screen-It just keeps coming back to that screen. There are a couple of times when it seems like the lil green android wants to come through but something knocks it to that same screen. Any other suggestions?
por
possible firmware issue, it could need reflashed, failing that it could be a cpu disconnection issue
por
Hi @amchjfj2xxe5cro
If you want to factory reset the tablet, use the steps you did to get to the screen in your image and then use the Volume Up or Volume Down button to step down the options in the screen until it highlights wipe data/factory reset.
When it is highlighted, press the Power button to select and then follow the prompts.
Be aware that a factory reset will erase all your data and downloaded apps. It will restore the tablet to its factory default condition.
It will be like when you first bought it.
Note: If there is a Google account associated with the tablet, then depending on what Android OS is installed, if it is >Android 5.1 you will have to know the Google account User ID and password to access and setup the tablet again after the reset due to the FRP (Factory Rest Protection) lock being enabled by the reset. This is a security measure introduced to protect your data in the event of the tablet being lost or stolen and other people trying to use it again afterwards.
If you just want to make the tablet perform a bit better if it appears slow etc, select wipe cache partition. This clears the temporary data from the tablet in case there's a glitch there which may impact on the tablet. Your data won't be affected.
Pontuação 1
4 comentários:
Thanks for responding but it doesn’t work-I’ve tried all the steps on that screen-It just keeps coming back to that screen. There are a couple of times when it seems like the lil green android wants to come through but something knocks it to that same screen. Any other suggestions?
por
@amchjfj2xxe5cro
Does the tablet work OK otherwise i.e. normal use of tablet?
por
It used to work. I put it away for awhile, I turned it on, pressed on an app & it shut down-I turned it back on and that screen appeared & Now, It won’t go pass that screen
por
@amchjfj2xxe5cro
About the only thing I can suggest is a power refresh.
Open the tablet, disconnect the battery, press the Power button for 30 seconds, reconnect the battery and check if it turns on.
Unfortunately I can't find a video online that shows how to open your tablet. maybe it opens like most. Here's an example that may help.
por
Adicionar a sua resposta
R R será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 770
