Ir para o conteúdo principal
screen working but blank
the screen is working but the screen is blank mobile touch is working but the screen is blank purely black
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Screen is black but can hear the on /off button is pressed
por Compartilhar
@supriyatalekar
Did you try what was suggested in the answer below?
por Compartilhar
Yes when i charge it vibrate but it screen is blank
por Compartilhar
Adicionar um comentário
1 resposta
Hi @asgamerguru
Check if the display flex cable is securely connected to the systemboard.
If it is then here are some images showing the no display troubleshooting flowchart from the service manual. I've included zoomed in images and normal size images showing the location of the components mentioned in the flowchart.
Imagem
Imagem
Imagem
(click on images)
If all the tests seem to be OK the screen will have to be replaced.
Search online for GH82-22836A GH82-22509A to find suppliers that suit you best.
Here's a video that shows what to do.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
asgamer guru será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 481
