Ir para o conteúdo principal
A série Mitsubishi MMCS NR-242 com SD é um sistema de navegação automotiva produzido pela Mitsubishi Motors que inclui um slot para cartão SD para maior capacidade de armazenamento. Foi sucedido em 2017 pelo Mitsubishi Smartphone Link Display Audio (SDA).
Black screen when updating
Hello,when trying to update, the screen has gone black and does not respond.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
The update failed. The screen has gone black. The mitsubishi dealer does not offer me a solution. Well, they offer me to change the screen at a price of more than €7,000 (it's not a mistake... €7,000!). i need an autorun to install the software again. Do you know how I can get it?
Thank you.
por
Adicionar um comentário
1 resposta
Solução escolhida
Have you turned off the car while the update was running?
Normally the unit should just produce an error code when it fails to update.
Disconnecting the cars' battery for 15 minutes should reset the device and enable you to try again.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you.
por
@carlosberm59725 You should go to an independent repair shop with good reviews and have them take a look at it.
If they can’t fix it you could maybe get them to install a used unit. You can get used units really cheap online and it’s just a relatively standard 2DIN module, so labour cost shouldn’t be too much. They might even be happy to source it for you.
por
Adicionar a sua resposta
Carlos Bermell Tormo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 42
Ao todo: 788
