Horizontal Lines after PRAM
Hello. I'm a bit of a novice with this but very keen to learn and also keen to not have to buy new.
We have a MBP 2011 that has developed a fault.
After booting the screen shows horizontal lines across the entire screen (see pic 1)
If left alone the MBP boots up and the screen displays a big old mess (see pic 2)
I have reset the SMC, taken the battery out and replaced it, checked the graphics connector and cleaned it, cleaned the fans in case of over heating.
Nothing worked.
When I reset the PRAM, the lines clear up after the second beep but reappear when left to continue to boot. (see pic 3)
Does this suggest that the hardware is ok as for a moment the screen is working correctly?
The cause of the fault - We were using a usb DJ controller, (that works fine on 2 other macbooks) after around 30mins the MBP shut down. The horizontal lines appeared on the next reboot.
Also we the same problem occurs when using an external monitor.
The pictures aren't the best but hopefully show the problem well enough.
Any suggestions or ideas would be very welcome, I'm all out.
Pic 1 - Faint horizontal lines
Pic 2 - Absolute horror
Pic 3 - Screen is clear of lines
Esta é uma boa pergunta?
