Ir para o conteúdo principal
Repair information for the fall 2018 addition to the ASUS ROG Zephyrus lineup. This is a high-end gaming laptop in the thinnest frame for those specs at the time. Model number: GX531GS-AH76.
14 Perguntas Visualizar todos
Using different edc cable
Hey, so i have zephyrus s gx531gxr. It uses 40 pin edc cable that i have to replace. I have ordered cable from similar model (gx531gx) by mistake, and I am wondering if this cable will work on my device. The main difference is that the gx531gxr has 240hz screen and gx531gx has 144hz.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@filipklaczek for as long as the pitch of the pins is identical it should work. I did not see any crossover etc, so I would definitely give it a try. After all, if it does not work, you will know that you need to get an original.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hi @filipklaczek,
If it doesn't work the Asus part number for a GX531GXR EDP cable is 14005-02780800.
Search online using the part number to find suppliers that suit you best.
por
Adicionar a sua resposta
filip klaczek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 64
