Ir para o conteúdo principal
Lançado em 2017, foi o modelo principal da empresa, identificado pelo codinome Sagit. Ele é equipado com o processador Snapdragon 835, acompanhado de 6 GB de RAM e GPU Adreno 540
How to replace screen
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Pergunta mais útil
@singgsirya iFixit does not yet a guide for this. Use the one from here to replace your screen. Since we do not know where you are located, I suggest an online search for a replacement screen within your part of the world.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 1
Display change
And power bottom change
Pontuação 0
1 comentário:
I'm going with the assumption you meant "button" rather than "bottom", because the phrase "power bottom" has a whole different meaning in this country than what you probably intended.
If you need to change the electrical part of the button including the click dome, use this guide.
https://www.nadiemellamagallina.com/en/m...
If you want to replace the physical part of the button that you press, use this one.
And see @oldturkey03's answer for the guide to replace the screen.
por Compartilhar
Mobile no the wrking
Pontuação 0
1 comentário:
Mobile display no werke
por Compartilhar
Adicionar a sua resposta
Singg Sirya será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 1,307
