Vizio m65-c1 repeating video pattern without audio disruption . until
HI, I hope that you're all well. I have a vizio m65-c1 that's been broken for about a year. I've refused my wife's consistent efforts for me to toss it, because I'm convinced that I can figure it out.
What happened is that it sporadically started freezing the video in some sort of a repeating pattern (could happen in 5 minutes or maybe 25 minutes, not really pixalated, just broken and forming a pattern across the screen), but the audio would keep going on whatever I was watching. After a minute or two, the TV would reset.
That's about it. I took it apart, and put it back together repeatedly, and its still doing it. I looked for bad diodes like I found on another vizio tv that I was able to successfully fix, but didn't find any here (for what that's worth). I did clean a bunch of some sort of salt deposit off the main board (everywhere on it), but didn't find any bad caps that might have leaked, though, that said, I'm mostly looking for obviously blown caps.
For what it's worth, I just shifted the TV to check the model and it had reset when I looked back at the screen. Maybe a bad solder joint, but since I haven't found anything, honing in on the problem area would be a huge help.
Any help would be appreciated. I hope to have this TV in my new office or shop if I can ever find a bigger house in this market. Could you please help me to identify the bad part so that I can replace it?
Thank you, much appreciated!
Best regards,
Josh
New photos:
T-con:
Esta é uma boa pergunta?
