AirPod case not charging
When I plug in the charger no light comes on the case I’ve tried different chargers please help!
Esta é uma boa pergunta?
Check two other things:
Try to reset the case and AirPods and see if that helps: https://support.apple.com/en-us/HT209463; if not, the case battery is bad. In this situation hopefully, they are under warranty because the case cannot be easily serviced to replace the battery due to how it is sealed; it's basically disposable.
Esta resposta foi útil?
Últimas 24 horas: 8
Últimos 7 dias: 47
Últimos 30 dias: 156
Ao todo: 12,194
