Ir para o conteúdo principal
O Dell OptiPlex 360 é uma solução de desktop com bom custo-benefício, construído com recursos práticos focados em oferecer valor empresarial essencial.
Motherboard is not working
Motherboard is not working properly
Esta é uma boa pergunta?
Pontuação 0
5 comentários
What part of the motherboard is not working? Can you give more details of the issue?
por
@kumailkazmi you really need to give us lots more information if you expect some help with this. At minimum we need to know why you think that your motherboard is not working properly. What make and model motherboard? What does or does it not do? What have you checked and what have you tried to fix this?
por
The fan did not spin
=== Update (09/17/23) ===
por
@amiribnmohammed if you need help with this you want to give us all the information. The fan did not spin is just to vague. What does your computer do? It overheats? Did it overheat because the fan didn't spin? Did you replace the fan? What did you check?
The only logical answer based on your question would be : Replace the fan.
por
Yes my mother board is not working
=== Update (10/01/23) ===
Yes mother board not working
por
Adicionar um comentário
1 resposta
Pergunta mais útil
might be a power issue with the powerbutton on the case, if so. short the pins using a screwdriver or somethign else
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kumail Kazmi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 498
