Touch Screen is automatically Working?
When I start using my phone after sometimes it's touch starts working itself and I press power button and then it works well for a few minutes.
Esta é uma boa pergunta?
Hello @bshhanaesharama,
It seems like a problem with the digitizer, but I could be wrong. Most likely, the fix is to replace the display panel.
Esta resposta foi útil?
@bshhanaesharama this is called a "Ghost Touching" and originates from a failure between the digitizer and the rest of the screen. You will have to replace the screen assembly. Use something like this video as your guide. Replacement screens are readily available and not to expensive. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Infinix hot 10 play automatically screen touch
=== Update (11/16/23) ===
@ayanmohsin read my original answer. Ghost Touch on your screen too.
@muez, If you're referring to the cable connecting the motherboard to the LCD, then I'm afraid you're out of luck. The connections to the glass screen require specialized equipment and cannot be done at home. While it is possible to repair a torn flex cable, that too is extremely difficult and needs someone with extensive soldering experience.
You could take it to a shop and possibly get it repaired, but I can't imagine it would be cheaper than just replacing the screen.
Well I think you are facing the issue of ghost touch on android issue on your device well this video might be helpful for you:
https://www.youtube.com/watch?v=7goCFKzv...
And also check out this blog as well for more solution to your problem: https://wethegeek.com/ghost-touch-issue-...
Screen automatically wark
@infinixhot11s, read @oldturkey03's answer; you probably need a new screen if you're having the same problem as the others here.
Well I think you are facing the ghost touch issue I will suggest you to checkout the following video:
Check if the screen can be separated from the touch screen ,separate them if possible,get a new screen touch and then fix.
@teetech35558 Modern screens all have the LCD/OLED display bonded to the digitizer using Optically Clear Adhesive (OCA). In order to separate the two, you need a vacuum table and wire guides to use a very thin, strong wire to slice through the adhesive. Then the old adhesive has to be thoroughly cleaned and new OCA applied. After reassembling the screen, it goes into a vacuum chamber to remove air bubbles from the OCA, and finally into a UV cabinet to cure the glue.
Far, far easier just to replace the whole thing.
Please use the steps below to help troubleshoot the problem.
1. Clean the Screen
• Ensure your screen is clean and free of dust, dirt, or moisture. Use a soft, dry microfiber cloth to gently clean the screen.
2. Remove Screen Protector or Case
• If you're using a screen protector or a case, it might be interfering with the screen’s sensitivity. Try removing them to see if the problem persists.
3. Restart Your Device
• Sometimes a simple restart can fix temporary glitches. Hold the power button and select Restart.
4. Update Software
• Make sure your device is running the latest software. Go to Settings > System > System Update to check for and install any available updates.
5. Calibrate the Touchscreen
• Some devices have a touch calibration option. Check if this is available in Settings > Additional Settings or a similar menu.
6. Check for App Conflicts
• Sometimes apps can cause touch issues. Boot your device in Safe Mode to see if the problem persists. In Safe Mode, only pre-installed apps will run. If ghost touching stops in Safe Mode, an app might be the culprit. You can usually enter Safe Mode by holding down the power button and then long-pressing the Power Off option until you see the Safe Mode prompt.
7. Preventive Measures
• To avoid future issues, avoid using the device with wet or greasy fingers, and be cautious of physical damage to the screen.
If the problem persists , back up your data and take your phone with its receipt to the customer service Centre for assistance.
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 47
Ao todo: 8,062
19 comentários
Yes it working
por Butt G Compartilhar
My touch screen is broken and half side of my mobile is blank showing black and some colorful lines
por Manoj Lohia Compartilhar
@manojlohia, read @oldturkey03's answer; you almost certainly need a new screen.
por Jerry Wheeler Compartilhar
My Infinix smart phone is automatically touching itself
por Joel Compartilhar
Touch screen automatically working
por bhubane Meher Compartilhar
Exibir mais 14 comentários
