Ir para o conteúdo principal
price estimates on repair
how much to change out the charger port and repair beats
Esta é uma boa pergunta?
Pontuação 1
1 comentário
add which country you are from as there are people from all over the world here
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Here's a guide that generally shows you the process to repair the charging port on Beats Solo.
Beats Solo 3 Charging Port Replacement
Note that this guide is for a Beats Solo 3, and your exact model may differ. However, the cost of the part itself is about $10 based on an online search. You will also need supplies for the disassembly as detailed in the guide. These supplies come out to about $60 if purchased through iFixit.
If you decide to get the headphones repaired as opposed to pursuing a DIY repair your rates will vary based on your location and the labor charge from your technician.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
chad castro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 40
Ao todo: 1,951
