Ir para o conteúdo principal
Why is speaker just stop
My speaker just stop talking
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@michaelomini now you did not tell us which OS your are using. If it is any kind of Windows, check the device manager and see if WIndows still sees your audio devices. I would suggest that you disable the current audio device drivers and reinstall the ones for your system. for the 5280 check on here
If that does not work, check your computer's BIOS to see if your audio is showing up in there. Consider running the diagnostics. Access that according to this site
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
michael omini será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 217
