Ir para o conteúdo principal
The second generation Rogue is a version of Nissan X-Trail and inspired by the Hi-Cross Concept to adapt to North American market.
10 Perguntas Visualizar todos
Power seat not working
My driver seat is powered and will still go up and down but won’t go forward or back? Not sure what could be wrong.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hello! It's possible that you have a malfunctioning track motor or one of the wires to it was damaged. That's where I would start.
Esta resposta foi útil?
Pontuação 1
@mecca92183 besides the prior answer, I would go through the SM that deals with the Seats and test the wiring. I have the one for the 2016 model but this should pretty much apply to the ones from 2013-2020. 2016 Rogue Seats Check if you have power to it and check the connectors with a test light, to see if your motor control works. If all of it checks out, it's possibly the motor. Again, you will have to go through the troubleshooting.
Pontuação 0
Adicionar a sua resposta
Mecca será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 56
Duração total: 859
