Ir para o conteúdo principal
A segunda geração do Rogue é uma versão do Nissan X-Trail inspirada no Hi-Cross Concept para se adaptar ao mercado norte-americano.
Power seat not working
My driver seat is powered and will still go up and down but won’t go forward or back? Not sure what could be wrong.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hello! It's possible that you have a malfunctioning track motor or one of the wires to it was damaged. That's where I would start.
Esta resposta foi útil?
Pontuação 1
@mecca92183 besides the prior answer, I would go through the SM that deals with the Seats and test the wiring. I have the one for the 2016 model but this should pretty much apply to the ones from 2013-2020. 2016 Rogue Seats Check if you have power to it and check the connectors with a test light, to see if your motor control works. If all of it checks out, it's possibly the motor. Again, you will have to go through the troubleshooting.
Pontuação 0
Adicionar a sua resposta
Mecca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 1,859
