Ir para o conteúdo principal
Where is ice maker reset button
where is ice maker reset button
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Hi @stuk,
What is the model number of the refrigerator?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @stuk
There's no reset button as such on the ice maker, only an On/Off switch.
If you haven't already done so, try turning it off, check that the ice bin is empty, wait a few minutes and then turn it on again and see if it now works OK.
Here's an image from the user manual (see p.32 onwards) that shows where it is located.
If still no good, here's the service manual see p.93-p.95 for how to troubleshoot the ice maker.
Esta resposta foi útil?
Pontuação 2
2 comentários:
That's what I thought until I read something that mentioned it. All is well overnight.
Thanks
por
The "craft ice" maker has a reset switch and this video shows where it is. Apparently, the standard ice maker does not (...which doesn't explain why mine isn't making ice...) https://www.youtube.com/watch?v=xJjEQa7w...
por
Adicionar a sua resposta
Stu K será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 31
Últimos 30 dias: 133
Ao todo: 5,614
