Ir para o conteúdo principal
O smartphone topo de linha da Samsung, o Galaxy S8. Lançado em abril de 2017.
How to make my screen visible
My phone fell, there is no crack. I can barely see the screen and apps. Its too dim. Please help me
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi @cynnerox
Even though there's no surface damage visible, that doesn't mean that the display didn't suffer any internal damage from the phone being dropped.
Here's the ifixit Reposição de Tela - Samsung Galaxy S8 guide that may help.
Once the phone is open you could check that the display flex cable is still securely connected and if so, then you would need to temporarily replace the display and check to see if it worked.
If the replacement also didn't work then there's a problem on the systemboard and further testing would be required to find out what's wrong.
If you decide to replace the display make sure that you get the correct one, (search using the model number for your phone) as there are different displays due to the many S8 variant models made for different phone service providers as the following version list shows:
Versions: G950F (Europe, Global Single-SIM); G950FD (Global Dual-SIM); G950U (USA Unlocked); G950A (AT&T); G950P (Sprint); G950T (T-Mobile); G950V (Verizon); G950R4 (US Cellular); G950W (Canada); G950S/G950K/G950L (South Korea); G9500 (China)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
cyy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Ao todo: 241
