Ir para o conteúdo principal
Informações e instruções de reparo para o freezer Frigidaire
Can this part be replaced?
Hi my son say something heavy on top of my Frigidaire upright freezer. He forgot opened the door and it fell. Busted the inside trim. Now my vacuum seal is weak. Can this part be replaced? How? If not can I still use the freezer with a weak seal ? Thank you in advance.
Update (06/26/23)
My picture I hope
Imagem
Update (06/26/23)
Model number is
LFFH17F3QWA
Thank you
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @mssharp,
What is the model number of the freezer?
por
Model number is LFFH17F3QWA
por
Adicionar um comentário
2 respostas
Solução escolhida
That part is absolutely replaceable. Going to a parts website with your model number, I looked up the piece you need. Here's the parts diagram; it's shown as part #10.
Imagem
So we're looking for Frigidaire part number 297403902; a google search turns up several sites selling it; here's one of the few ones with a picture.
Freezer Breaker Strip, Lower 297403902 parts
Imagem
As to how to actually replace that part; I have no clue. Hopefully some of our professionals here can help out with instructions.
Update (06/26/23)
P.S., As a stopgap measure, you can cover that crack with some heavy duty packing tape; that will smooth the surface sufficiently to allow for a good seal on the door.
Update (06/26/23)
I didn't have much luck locating any information about replacing the part you need, other than the fact that it's part of the "breaker strip", which is the plastic around the edge that the door seal comes in contact with. There was one generic page that wasn't completely useless, but I don't know if it'll help.
How to Remove the Breaker Strips - Refrigerator Repair Guide - ACME HOW TO.com
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you. So much Now just need to get part and figure out how to remove and replace
por
Once again I just want to say thank you. You were a great help
por
If it is a rubber seal it can be replaced by going on line checking for appliance parts using the name and model number. If it is the plastic that is broke you can repair it by using a sealer for plastic repair but it will need to be smoothed out so the lid will close evenly. I have been repairing appliances for more than 25 years and I had to do this with my own freezer.
Pontuação 0
2 comentários:
Thank you. But it is not a lid. This is a upright freezer. It is the hard plastic on the cabinet that kinda frames it
por
Gorilla glue will fix it!
por
Adicionar a sua resposta
Ms. Sharp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 585
