Ripped battery connector from logic board
Hey there,
Unfortunately, I ripped the tiny battery connector from the logic board, while trying to take out the battery (picture attached). Is there any way to repair that or do I need to replace the logic board?
Update (06/19/23)
Here’s another picture attached. The object (plug?) in the green circle would needed to be placed where the red arrow is pointing to. While trying to take off the cable i ripped it of the logic board.
Esta é uma boa pergunta?
2 comentários
Have you repaired this?
por Siva Natarajan
@sivanatarajan - Depending on what happened!
Some people break the connector often snapping out the ZIF connectors compression latch so you either need to find it on one's desk or floor to put it back or you need to buy a replacement connector to snap it out and snap it into your boards connector.
Some destroy the connector in the process of getting the ribbon out not realizing this is a ZIF connector needing a full replacement of the connector.
Then some damage the cable over bending it or mangle the contact area so when the ribbon is inserted into the connector it doesn't offer a good contact when the compression latch presses it into the connectors contacts requiring a new cable.
Then the act of prying the connector damages the PCB by lifting the connector off the PCB you either have all the solder pads still present or one or two are ripped off and you need to patch the damaged line.
por DanJ
