Ir para o conteúdo principal
O Logitech Ultimate Ears Boom 3 é um alto-falante Bluetooth portátil lançado pela Ultimate Ears em 2018. É o sucessor do modelo Boom 2, lançado em 2015, e do modelo Boom, lançado em 2013.
Not turning on, nothing
I think it might be a faulty usb or battery and there is a guide to these on another very similar speaker the UE boom but this has none why is that and why is it not turning on
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
@dantheman36801 the reason for not having a guide, is because nobody has made one yet. Those guides are commonly created by users like you and I and not the iFixit staff.
As for your UE Boom 3 not coming on, you will have to take it apart and check the charge connector. You'll have to measure the voltages on the board once you connect your charger. Of course, you made sure that your charger and charge cable are working properly and do not have any bend broken or corroded pins etc.
To take it apart use videos like this ++++Once you are in it, post some goo pictures of all of your circuit boards. That way we can see what you see and hopefully help you further.
While you work on your speaker, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
DAN THE MAN será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 900
