Ir para o conteúdo principal
Informações de reparo e guias para o Apple iPhone 5c, anunciado em 10 de setembro de 2013. Modelos: A1532, A1456
thermal paste under battery?
Imagem
well, i used a heat gun on this phone to remove the battery... and i notice something sliver under the battery... and the adhesive tab didn't budge (and ended up ripping)
Imagem
Imagem
yeah it was kinda hard to see, but still is this normal...?
is this just the base but damaged?
edit its not... it crumbles when you get something under it.. could it maybe be thermal paste....?
Esta é uma boa pergunta?
Pontuação 1
26 comentários
There shouldn't be any thermal paste under there. it would be useless. Any chance you poked through the battery/tore it?
por
@oldturkey03 more than likely the inside of the battery
por
@tech_ni that is what I was thinking. The crumbling would make me think it is :-)
por
@oldturkey03 did know people still bought 5c, i binned about 8 housings with parts
por
@oldturkey03 won 2 items on ebay today for repair, iphone 8 no power for £8.50 and a gopro hero 8 for £17.50 with no power
por
Exibir mais 21 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Could be the old adhesive. Seems to be in the right place. If the tabs break off I either use a heat mat and a spudger to gently lift the battery or put some alcohol down the side of the battery and tilt the phone so it runs over the adhesive.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
timtom77 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 499
