Ir para o conteúdo principal
The Subaru Forester is a compact crossover station wagon manufactured since 1997 by Subaru. Available in Japan from 1997, the Forester shares its platform with the Impreza.
Moon roof motor replacement
How do I replace the motor on the moon roof. 2003 Subaru Forester?
Can I order the motor from some where other than Subaru?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@jamesbyrne96190 should be the same way as the FSM lists the sunroof motor. Biggest job will be the roof trim removal. This is for the motor
Imagem
and this for the trim Forester Trim Removal. AS for getting the motor from other places, that will depend on where you are. I'd do an online search and see what pops-up
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
James Byrne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 22
Ao todo: 359
