Ir para o conteúdo principal
Repair and disassembly information for Samsung's S22 Ultra smartphone, released in February 2022.
20 Perguntas Visualizar todos
Will a screen replacement fix bad flickering after a drop
My phone fell out my pocket and there’s a crack that goes across the phone from one end to the other. The top half shows a fine display but with the bottom half the screen is flickering really bad and you can’t see anything. The display is completely messed up on the bottom half and the phone is useless. If I replace the screen , will it fix all this or do I need to get anything else fixed?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
I have a similar problem, my phone was dropped & cracked, screen was only showing the top half. Didn't notice any flickering until after the screen was replaced. I've done everything that the internet says to do with no result other than I have waisted several hours taking the phone apart twice & hours upon hours of reading the same "solutions" that does not seem to be working.
All I know to do now is to return the screen. I'm tired of messing with this P.O.S.
(Brand newish Samsung S22 Ultra.)
por
So you have half of the screen no touch responding?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
yes, it will, but....
have you tried reseating connectors on the board before you waste money on a screen?
im assuming there is no cracks as you didn't mention them, but if there is youmight just need a new screen as cracks can cause weird glitches, but if there are none, try reseating the screen connectors
Samsung Galaxy S22 Ultra (USA) Screen and Battery - Genuine
Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement
Imagem de Replace a screen and battery assembly for a Samsung Galaxy S22 Ultra smartphone for the US market. Fix issues like a scratched screen, touch issues, or a dead battery. 6.8 Inch 1440 x 3088 pixel AMOLED Display.
Produto
$232.99
Esta resposta foi útil?
Pontuação 1
COMPLETION ANSWER: Poor answer quality
When it comes to Samsung phones with a screen where part of the screen is bad (especially after being dropped), it almost always leads to a replacement screen :-(. The issue with Samsung phones has always been screen cost; for example, I have someone on the family side who has the S22+. He managed to break this one, too, and he broke it, increasing the high score to 7 devices killed due to screens. Sigh :/...
The guide posted by @timtomissus is correct for your phone, but you almost certainly damaged the screen and have to spend close to ~$250 to fix this phone.
Pontuação 1
Adicionar a sua resposta
Londyn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 33
Duração total: 1,021
