Ir para o conteúdo principal
Lançado em 2017, o Dell Inspiron 5570 é um laptop de 15 polegadas com um processador Intel acompanhado por uma placa gráfica AMD dedicada. Ele também é referido como "Inspiron 15 5570".
SSD Not working after hearing
This happened a while ago I have an external fan so I don’t really care about heating but one time my laptop was so hot that it just closed after I turned it on the next day I just hear beeping sounds and my 2TB ssd or hd not there there’s no drive D I tried everything but it’s not working, That was about a month ago and it still makes this beeping sound
Update (06/08/23)
Imagem
this is the pic idk how to send it as a comment
Esta é uma boa pergunta?
Pontuação 0
4 comentários
You say you tried "everything". Can you specify what you tried? It helps us come to a solution.
por Compartilhar
Hi @yaso39064,
Count the number of beeps.
There will be in a repeating pattern e.g. 3 beeps - pause 3 beeps - pause or 2 beeps - pause - 2 beeps etc.
The beeps indicate what the error code is and knowing this makes it easier to find out what's wrong
por Compartilhar
@guardian10 I did not try to open it yet because I don’t wanna break anything, I tried to see if there was anything in device manager there wasn’t it just read my C drive, then I noticed when I connected a usb or disc it showed as Disc drive D the old name after and renamed it and still no signs tried using one of those apps that manage the disks not working even shortcuts doesn’t open the shortcuts that where to the disc drive D it just says : “the drive or network connection that the shortcut ‘Name.ink’ refers to is unavailable make sure that the disk is properly inserted or the network resource is available, and then try again”
Note : by open it i mean hardware screws stuff
por Compartilhar
@jayeff https://mega.nz/file/tGgkiRTJ#S9zvqSyHrh... you can hear it here but for confirmation i think it is a 1 beep pause 1 beep etc
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi @yaso39064
A 1 beep error code is a motherboard or BIOS Rom failure
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Disconnect the main battery from the motherboard.
c). Remove the RTC coin cell battery from the motherboard.
Here’s the service manual applicable to the laptop. Go to p.21 and p.30 to view the procedure to remove the battery and the RTC coin cell battery respectively.
When the RTC battery is removed measure its voltage. If it is <2.6V DC replace it. It looks like it is a CR2032 coin cell Lithium battery which is commonly available everywhere e.g. supermarkets
d.) Reinsert the RTC battery (or its replacement). (+ve on top as marked on the battery)
e). Reverse the above steps to re-assemble the laptop.
f.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
Esta resposta foi útil?
Pontuação 2
9 comentários:
Is there anyway I can do these things from home because for me I never done it before or opened it only shops for cleaning?
por Compartilhar
@yaso39064
I've linked the service manual in my answer (see under Step c). and click on the blue "service manual" link) and stated where to look in the manual.
It's all there.
por Compartilhar
Thx mate I will try it and will give my answer
por Compartilhar
@jayeff I did all of that just an hour ago I tested it with the charger on but I do not have supplies to do the cmos testing so I took it out and back in it did a bios thing but the disk is not showing still if you need a pic tell me
por Compartilhar
@yaso39064
Do you get the Dell logo when you start the laptop?
If so try to get into BIOS (press F2 when the logo is on the screen) and check if the SSD and HD are shown as being detected in it.
If there's no logo or you can't get into BIOS then there's a problem with the motherboard
por Compartilhar
Exibir mais 4 comentários
Adicionar a sua resposta
Yaso será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 619
