Water Repair Bold 9700
How I Can Repair A Water Damage?
Esta é uma boa pergunta?
Guillermo Eirin, I would start by disassembling the phone and cleaning it. Use this as a general guide. You can find a teardown for your phone right here. There is also a take apart guide on here. . Hope this helps, good luck.
Esta resposta foi útil?
Shake and wipe water off , open phone and wipe parts (try with a non static cloth ) put phone in a bowl of rice for a couple of minutes(30) that will take out extra water if next day it does not come on get a new battery and see if problem continue if it does get a new phone .
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 2,422
1 comentário
most likely you will need a new battery, once you have cleaned the phone I'd buy a new battery and then see what if anything works, get back to us.
por pollytintop
