Ir para o conteúdo principal
Philips 58PUS8105/ 12 4K Luz ambiente
Blank Screen- sound works.
Hi,
In need of some advice/ help and having read so many helpful questions, answers and solutions, I wanted to reach out to see if anyone has any idea.
The screen has suddenly gone blank, I’ve tinkered with a few TV’s over the past year or so, so I’m comfortable taking the TV apart etc.
Backlights are fully working so they’re not the issue.
Unplug 1 of the T-Con board Cables and half the screen displays as normal, plug that back in and repeat for the other T-Con board Cable and the other side of the screen works and displays what you would expect.
Clean T-Con Cables and their respective sockets, plug both back in and no image displayed.
Am I correct in assuming this is a Faulty T-Con board or is it likely the Video board is at fault?
Any help would be really helpful
Regards
Shep
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
i have the excactly the same issue. is it fixed with u in the meanwhile and if so what was the fix with u?
por
Adicionar um comentário
1 resposta
@shep67506 according to your tests, I would start with the T-con board. Your main board is sending the right video signals to the T-con board For now the possibility of a bad main board would be pretty low on my list. If anything, it is something past the T-con board that would prevent your picture from displaying. T-con board first, Then re-evaluate.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Shep será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 1,345
