Switching on the bulb
My washroom's bulb always blinks several times before comes to proper working condition. So what is the reason behind this?
Esta é uma boa pergunta?
@muhammedsa33137 take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Adicionar imagens a uma pergunta já existente
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Guia
Moderado
30 minutes
Guia
Moderado
Esta resposta foi útil?
It may be that the electronic components in the LED light are beginning to fail. Usually it is the capacitors in the light as they may fail prematurely due to the heat generated by the operation of the LED light.
It could also be that the light is loose in the light fitting, making for a poor electrical connection
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 524
3 comentários
Hi @muhammedsa33137,
Please verify the type of bulb e.g. Incandescent, CFL (compact fluorescent), Fluorescent tube or LED.
por jayeff
It is an LED bulb.
por Muhammed Saad Islahi
My bulb is not working what i do?
por Hassan
