Oil is coming up from the top
How can I fix an oil leak from the cover
Esta é uma boa pergunta?
As @nytryder26 already said, we'll need to see what you see in order to get an idea about what issue you're having. That will also help us try and figure out where the oil is coming from, which will determine what kind of fix is appropriate.
Off the top of my head, two possibilities come to mind. First would be a valve cover gasket leak if the oil is coming out from around the top of the cylinder head; the obvious solution to that would be to replace the valve cover gasket.
Other than that, the next most common cause for oil to appear on the top of the engine would be from excessive crankcase pressure blowing oil back out the fill cap, PCV valve or other vacuum connections. High crankcase pressure usually results from either piston rings that are shot and no longer able to contain cylinder compression, or a leaking head gasket. Obviously the fixes for these kind of issues are going to be a lot more difficult and expensive.
But add some pictures so we have something to go on; these are just conjectures of things that could cause the appearance of oil and may or may not have anything to do with your actual problem.
Esta resposta foi útil?
Thanks for explaining it more, I had a massive eye ache when I was typing.
These engines are known for oil consumption, especially the 2AZ-FE; it's a known issue Toyota has a TSB for that essentially says piston rings are bad. It's available from the NHTSA. The problem affects nearly all of the 2AZ-FE engines from 2002-2008, and potentially the 2009 version used in the VX40 Camry. 2010 and up have since fixed this as it uses a different engine.
Outside of rebuilding the engine, it has to be monitored. You'll also need to change the sparkplugs more often as well as they will get fouled up; instead of your normal ~80-100k replacement cycle, it's going to need to be done at ~60-70k, and inspected on a somewhat regular basis.
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 35
Duração total: 331
1 comentário
First you will need to add pictures, heres the link: Adding images to a new question
por NR26
