Ir para o conteúdo principal
Renascimento moderno do automóvel clássico de John Cooper, fabricado pela BMW.
Bonnet release cable is broken
Can anyone tell me how to open the bonnet when the Cable relese from inside the car is broken?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
How broken? Is the handle broken but exposed or did the cable break someplace deeper in the car? Where is the handle located? The more info you can provide, the easier it will be to provide an answer.
por
use pliers topull manually the wire
por
Adicionar um comentário
2 respostas
Solução escolhida
George, usually when the cable breaks,it is at the cabin end of the cable and not the engine side. Take a look underneath your your dash, you should be able to see the broken end. Grab a hold with a pair of pliers and pull the end, the hood should pop. There is also the possibility that the cable pulled out of the little bracket at the release lever. You might still open the hood, by holding the sheathing and pull on the cable. A pair of vise grips may make that job easier. I found this little tidbit of information on your Mini on here
"Using a hacksaw blade, you can ease the kidney grills out of the bonnet, this allows you to release the left hand bonnet release by yanking on the cable that runs under the front cross member. You can't get to the right hand one through here though.....
To release the right hand one, pull off the lens cover from the RH headlamp. EEEeek I know!!!!! , but mine didn't break and all i'll have to do is silicon it back on after the plastic clips broke. This reveals a space behind the indicator that allows you to ferret around to locate the release cable that runs over the headlamp and up the inner wing."
Esta resposta foi útil?
Pontuação 3
1 comentário:
Posts link to thread about opening the bonnet on a BMW.
por
Thanks for the tips, I’m still searching for a less destructive method of popping the latches , even if it takes more time or tools to do so.
Pontuação 1
Adicionar a sua resposta
George será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 54
Ao todo: 27,360
