Ir para o conteúdo principal
Lavadora Whirlpool WTW4816FW ou a lavadora Maytag Centennial MVWC415EW2.
spin cycle not fully done
Clothes still wet and not spun against side of tub at end of washing. Pump working. New synchronous motor. Belt inspected. Clutch manually engaged when replaced synchronous motor. Seems to work just fine( the clutch).
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Hi,
Please verify the make and model number of the washer?
por
Adicionar um comentário
1 resposta
The pump is probably clogged up with a penny or something small.
The pump will still come on but cannot drain. Check the L in the hose on the pump.
Washing machines have a catch all type net or something like that to catch rings,pennies, & such.
I'm no expert but that's what I had an issue with.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dan And Monique Carson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Ao todo: 496
