Ir para o conteúdo principal
O eMachines ET1831-05 é um sistema de desktop econômico produzido pela eMachines.
Green power Light keeps blinking
Green power Light keep blinking
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Press and hold the power button operated for >10 seconds and then release to ensure that the PC has fully shutdown in case it is in a sleep or hibernate state.
Once it has shut down try turning it on and check if it starts OK
If it doesn't start and boot into the OS then try a power refresh and check if that resolves the problem.
  • Turn off the PC and then disconnect the power to the PSU.
  • Open the PC and remove the coin cell RTC battery from the motherboard. (Once the battery is out, check its voltage. If it is <2.5VDC, replace it. The battery model number is stamped on the battery itself - CR2032 perhaps).
  • Press and hold the Power button for a full 30 seconds and then release it.
  • Reinsert the RTC battery into the battery holder on the motherboard (remember its orientation, usually +ve on top as marked on the battery)
  • Reassemble the PC, reconnect the power to the PSU and turn it on and check it it works OK.
If it turns on OK there may be a message stating that the time and date are incorrect. This is normal as the BIOS has been reset. Once the D&T have been corrected the message won't appear the next time that the PC is started.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanx I'll try getting another battery
por Compartilhar
Adicionar a sua resposta
ml3748915 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 570
