Transmission has no up shift
No up shift from second gear
Esta é uma boa pergunta?
Is it an automatic? Most likely it's the Auto Trans Computer. A common problem throughout the 1990's built models. I've personally repaired thousands. Problem often starts with electrolytic capacitors and you can smell it. Leaking / exploding ones often pop the uP chip. Can also be the sensor, but you will need to measure to see if it's switching.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 36
Ao todo: 543
Hi,
What is the year model of the vehicle?
por jayeff
