Battery cable is too short
If the cable/terminals to the battery isn't long enough to reach the post, can I purchase an extension to make it longer ???
Esta é uma boa pergunta?
@linnyk did it fit before? There should be no reason to have a short battery cable. Make sure that you have the right battery and have it in the right orientation. Batteries are not all build the same. Sometimes the post are on the opposite ends, so make sure that the battery you have is indeed for your vehicle. If it is, try to turn it around and see if that fits.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 365
