Ir para o conteúdo principal
O Motorola Moto G Pure 2021 pode ser identificado pelo número de modelo: XT2163. Lançado em 14 de outubro de 2021 pela Motorola, este smartphone possui uma tela HD+ de 6,5" e um chipset Helio G25.
Phone is completely frozen.
The phone is completely frozen. No buttons work, touch screen don't work, the call time and clock is frozen also. What is the reason and fix for this????!!
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Solução escolhida
@oldturkey03, there was really nothing to tell. I tried to power it off the conventional way. But as I said, nothing was working. Even the screen had frozen in time. However, I was able to do a soft reset by holding all 3 buttons on the right side off the phone until it powered down and restarted. It is now working fine. Thank you for your response nonetheless.
Esta resposta foi útil?
Pontuação 1
1 comentário:
@warlock1515 Glad you got it working again. Sometimes even the best software glitches :-)
por
Pergunta mais útil
@warlock1515 you are not telling us what you have tried. Also, is there anything you know off that may have happened to the phone. Anyhow, her are a few things that you want to try first.
REstart the device
  1. Press and hold the Power button (on the right edge) until the power menu appears then release.
Should that not work try this
Press and hold the Power button and Volume down buttons (on the right edge) for approximately 10 seconds or until the device powers off. If your device doesn't automatically power back on, partially charge the device then press and hold the Power button until the Motorola screen appears.
Let us know if this changed anything.
Pontuação 3
1 comentário:
When gets close 2 full apps stop working outta the blue and freezes up. Just delete few apps don't use much. And log out first
I took peacock off and another. No more problems since. Moto g pure!!
por
Yes is broken screen touch
Pontuação 0
1 comentário:
@hnvzuf6vkdisl2w sorry but no it wasn't. The OP stated that "holding all 3 buttons on the right side off the phone until it powered down and restarted. It is now working fine." It is important to read through the complete thread.
por
Adicionar a sua resposta
eric q moss será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 38
Ao todo: 6,949
