Ir para o conteúdo principal
Looking for a source for replacement batteries?
Where Can I source replacement batteries?
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Bruce Lotimer yours is a Black and Decker BDH9600CHV? Just making sure.
por
Thanks for the reply. A project for this week.
por
== Replacement batteries for BDH9600CHV? ==
por
@tony88169 batteries are no longer available. You have to build your own.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Bruce Lotimer it seems like nobody makes or sells those anymore. Surprise right? Again lots of Dustbusters out there that get thrown away because parts are not available. Anyhow. Are you handy? You can actually create your own battery pack and it is not rocket science and not as scary as it sounds. Pretty much the same idea as on here Substituição da bateria da chave (de fenda) Black and Decker 9074 All we would need to know, is what numbers your Ni-Cad battery cells show. You can post pictures of your battery with your Question. That way we can see what you see. Adicionar imagens a uma pergunta já existente Use this guide to at least get to the battery Substituição do motor do Black and Decker BDH9600CHV
If you are not handy, see if you have some handy friends or relatives that will do it for you. Does not take long, not very expensive to build and it will keep your vacuum going. Let's keep stuff out of the landfill and our hard earned money in our pockets, not B&D shareholders. Remember that
Repair is War on Entropy
Imagem de Black and Decker 9074 Type 4
Guia
Nível de dificuldade:
Moderado
30 minutes
Imagem de iFixit
Guia
Muito fácil
2 - 5 minutes
Imagem de Black and Decker BDH9600CHV Motor
Guia
Difícil
30 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Bruce Lotimer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 513
