Ir para o conteúdo principal
Suporte para computadores desktop da Gateway. A Gateway atualmente pertence à Acer, e qualquer produto novo da Gateway é suportado pelo Grupo Acer.
no monitor or visual display
gt4010 is the gateway pc
computer boots but no display , ive used several monitors , and still nothing i have a repair disc , any tricks ?
Update (01/29/2023)
no video card , i just hooked up other monitors and cables , to make sure it wasn't one of those .
Esta é uma boa pergunta?
Pontuação 0
4 comentários
@do you use a video card or are you using the integrated video card? What have you checked on your computer? Just to verify, your computer is a Gateway 420GR
por
@dapose it's all good, no worries:-) Let's see what we can find out.
por
hopefully the PC guru's like @aactech or @jayeff can assist you with this.
por
@dapose,
Are you sure that it is booting up e.g. Windows welcome sound etc?
The 420GR has integrated graphics in the CPU therefore it may be failing to POST.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
As far as I know this Gateway GT4010 does not have integrated graphics with the Athlon 64 CPU so you will need a video card.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
randall será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Ao todo: 377
