Ir para o conteúdo principal
Reparo e resolução de problemas da calculadora científica TI-30Xa.
Certain Buttons Won’t Work
The 1,5 and subtraction button on my calculator won’t work. Can this be fixed or should I just buy a new one?
Esta é uma boa pergunta?
Pontuação 1
3 comentários
A goggle search shows current (2022) prices between $13-$22. Electronic calculators in general are not repairable.
por
@Papaya Bear
I suggest that you have a look at the excellent answer from @jayeff below:-)
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Use a Q-Tip lightly moistened (not dripping wet) with Isopropyl Alcohol 99%+ (available at electronics parts stores) to clean the contact surfaces of the board for the buttons that don't work.
Do not clean the contact surfaces of the buttons themselves as you may remove the conductive coating from the underside of the button.
Here's the ifixit Desmontagem da Texas Instruments TI-30Xa guide that will help. Go to Step.5 to view the image of the board showing the button contacts on the board.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Papaya Bear será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 562
