Ir para o conteúdo principal
O Galaxy J6, lançado em 2018, veio para substituir o Galaxy J5.
My touch does not work anymore
My mobile samsung j6 had fallen down from my bed to a distance of 2 metres. From then my touch is not working,
but there is no crack on the screen due to it.
It is working as perfectly as it can when I connect it to USB mouse or keyboard.
Is there any way I can retain my touch back without replacing a part?
(OR)
Is there any way I can retain my touch back by replacing a part and what part it can be and where can I get it?
(Even the smallest answer would be greatly helpful to me.)
Esta é uma boa pergunta?
Pontuação 3
1 comentário
My phone has follen down but no crack and and the screen also glowing but touch is not working
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hemasai Duppalapudi sounds like your touchscreen got cracked. Yes, there is a possibility that it is a loose connection on the main board but chances of that happening is slim. You will have to replace the display assembly, which includes your touchscreen. Use something like this video or even this Substituição da tela do Samsung Galaxy J6 as your guide. Replacement screens are readily available and prices are reasonable.
Esta resposta foi útil?
Pontuação 3
2 comentários:
My phone touch was not working
por
@samsung18678 same answer for your phone!
por
hp lama saya suka nge lag. sentuhannya butuh waktu beberapa menit. buka apk yang menggunakan internet,tidak bisa. padahal penyimpanan masih banyak
Translate Indonesian - English
My old cellphone likes to lag. the touch took a few minutes. open the apk that uses the internet, can't. even though there is still a lot of storage
Pontuação 0
1 comentário:
@bili74026 make and mode for your phone?
@bili74026 merek dan mode ponsel Anda?
por
Adicionar a sua resposta
Hemasai Duppalapudi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 1,228
