Ir para o conteúdo principal
O HP Pavilion 14m-cd0005dx é um notebook com tela tátil projetado pela HP. Ele possui uma tela na diagonal de 14,0 polegadas com resolução de 1366 x 768 pixels.
Guidance on Screen replacement
How much more difficult does “touch screen” function make replacement? Are there many more caveats to screen replacement?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@eeandersen it is not much more difficult. You will just have a few more cables and connectors. Essentially the same work. You can download the maintenance and service guide for the HP Pavilion x360 14m-cd0005dx from here It'll guide you through the repair
Esta resposta foi útil?
Pontuação 1
1 comentário:
@eeandersen, On your laptop the touch screen function is integrated into the LCD display, so there isn't any separate part to deal with; in fact, you can't replace them separately. As @oldturkey03 mentioned, there will be one more connector to route and plug in for the digitizer, but that's it for the difference between replacing your display and a simple LCD replacement.
por
Adicionar a sua resposta
Eric Andersen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 300
