Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
20 Perguntas Visualizar todos
Apple Watch Series 3: Should I replace my battery?
Hello!
I have an Apple Watch Series 3 that has been in storage for a long time: 3 years. However when I first opened up the box, the watch does not turn on. I have tried charging it, but no luck. No vibrations, or screen life. Nothing works even with a "hard" reset. However whenever I charge it, the watch does get warm. I was wondering if this is a battery issue, or could be a display issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@kneemo based on this "that has been in storage for a long time: 3 years", absolutely. The Apple Watch battery will have to be discharged below it's threshold and will definitely no longer hold a charge. Replace the battery, then re-evaluate. Apple Watch Series 3 Battery Replacement
Esta resposta foi útil?
Pontuação 1
2 comentários:
Appreciate the response! Even though it gets warm, does it mean the battery is active though?
por
@kneemo getting warm could just be from your charging circuit trying to charge the battery. It means a charge is applied but will not get stored
por
Adicionar a sua resposta
Ronald será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 210
