Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Changing cooling paste on MacBook Core 2 Duo
I have a question about changing/refill the cooling paste on a macbook core 2 duo. The CPU in my macbook is often very warm when I'm running small processes. I'm thinking about refill the cooling paste, so does anyone know how to refill it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Yes it's a good idea to replace the thermal paste when you have a heat issue with your macbook or for heat problem prevention specially if your machine is aging. Once the heatsink and the fan are removed from the mac you should also consider a fan clean up with compressed air. You can also easily open the fan, dust it off and clean the blades with isopropyl alcohol.
For the thermal paste replacement please click these links:
MacBook Core 2 Duo Heat Sink Replacement
How to Apply Thermal Paste
Imagem de MacBook Core 2 Duo Heat Sink
Guia
Nível de dificuldade:
Difícil
45 minutes - 2 hours
Imagem de Electronics Skills
Guia
Moderado
5 - 20 minutes
Esta resposta foi útil?
Pontuação 6
Adicionar a sua resposta
Morten Kvisvik Larsen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 11,815
