Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Perguntas Visualizar todos
iMac 27-inch, Late 2012- Problem with 3 b4 slots for RAM
Hello. My Imac (27-inch, Late 2012) has the original memory (2x4GB Elpida) in slots 1 and 2. When trying to install in slots 1+3, 1+4, 2+3, 2+4 it beeps three times and the Mac does not start. Replacing the original memory in slots 1+2 with new memory (2x8GB) is successful. Can not add memory to slots 3 and 4 (old memory or new). Please advise where to look for the problem.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
As you can see here your system can support 32GB!
But you need the correct SO-DIMMs
PC3-12800 1600 MHz DDR3L SDRAM (204-pin)
27” iMac "Core i5" 2.9GHz
27” iMac "Core i7" 3.4GHz
por
Adicionar um comentário
1 resposta
If you have the correct RAM, then make sure the SO-DIMM’s are properly inserted and the contacts are clean.
Esta resposta foi útil?
Pontuação 0
2 comentários:
original memory installed in slots 1 + 2 or 1 or 2 works fine. If the original memory is installed in slots 1+3 or 1+4 or 2+3 or 2+4 or 3+4 or 3 or 4. Slots visually clean, slot 3 and 4 do not differ from 1 and 2. Maybe the problem is in slots 3 and 4 ?
por
@Олег Б. - Then the RAM slot is damaged.
por
Adicionar a sua resposta
Олег Б. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 111
